I have tried to get PAC code - it says there is a system fault. Is this likely?
is PAC code facility down?
Best answer by Tom
We have recently had an issue with our PAC code systems, apologies for any inconvenience caused with that, however we believe it should be all up and running again now, so PAC codes can be given/gotten.
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
