phone wont make calls or receive
  • January 24, 2025
  • 6 replies
  • 136 views
Hi, my phone can't receive or make calls for the last 24 hours ..everything else works!
Very frustrating as needed for work!
Please can you help ASAP!
Stardust
Helpful
  • Helpful
  • 15 replies
  • January 24, 2025
Turn off phone. Re-start.
Bullen
  • January 24, 2025
I found my issue was with call forwarding being turned off? Had to also put my number in phone settings to get the call forwarding to work .
  • January 24, 2025
Thank you, I've tried still doesn't work
  • January 24, 2025
Thank you, I've tried that it won't let me put my number in now! ...I've also disconnected from network, rejoined and restarted/ plane mode for a few minutes and back on nothing!
I still have 4g/5g and can access Internet but can't call or receive phone calls!!
Spoken to 3 people today from id mobile and they keep saying it will come back...its been over a day now!
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
Hi ​@Alex89
Have you checked the coverage for your area?
Has the 3G signal been turned off in your area recently?
Is your handset on the approved list?
Can you still use your data and send/receive texts?
What phone do you have?
Do you have VoLTE enabled on your phone? VoLTE is Voice over LTE and is the type of connection used and so you need to see LTE in your network connection (4G is only a label for the 4th Generation network and NOT the actual signal used).
You could also try requesting a replacement SIM as this could be the problem.
Please be aware that your account will be put on hold (you will be unable to use that number) until the new SIM has been activated.
There are a few different ways to get a replacement SIM. Here’s everything you need to know:
How do I get a replacement SIM?
If your SIM card doesn't fit your phone, or it's been lost or stolen, you’ll need a replacement. To get a replacement SIM card, you can:
  • Visit any Currys store.
Find your nearest store and head to the ‘Mobile’ section. One of our helpful Tech Experts will issue you a replacement SIM card.
  • Chat to us.
Our Live Chat team are able to issue you a replacement SIM card, which will be sent in the post to the account holder’s address.
Once you receive your replacement SIM card, you’ll need to activate it. Check out the steps in the article below:
Let us know how you get on x
  • 4825 replies
  • January 26, 2025
Hey there ​@Alex89,
We’ve had confirmation that the issue is now fully resolved, and calls are functioning as expected. Thank you for your patience and we apologise for any inconvenience this has caused you.  
If you’re still unable to make or receive calls, please try restarting your phone, or toggling Airplane Mode on and off.
For latest updates, please see:
https://community.idmobile.co.uk/contacting-id-183/some-customers-are-unable-to-make-or-receive-calls-72269
If still having any issues, please do let us know.
