Voicemail Icon Doesn't Appear
Kevin Greaves
I have a Galaxy s21+ and my voicemail is turned on. Today I had two calls that went in to my voicemail, just couldn’t answer the ringtone at the time. When I looked for a notification there wasn’t any however, when I went into my voicemail there was two messages.
How do I get an icon to appear on my home screen, so I know they are there?
Many thanks
Kevin
Kevin Greaves wrote:
Thanks for this.  How do make it that I receive an SMS Alert?
Okay @Kevin Greaves,
To set this up:
  1. Call 123 from your handset with the iD SIM
  2. Enter your voicemail PIN, if you have one
  3. From the main menu, choose option 4, then option 0, then option 3, then option 1
You’ll then be able to stop/start your voicemail alert SMS as required.
Good luck...
  • 12413 replies
  • May 24, 2022
Sadly iD Mobile don’t have a voicemail notification, there’s just an SMS alert for voicemail.
The voicemail service is actually provided by three (iD Mobile’s network partner), which might be why iD don’t provide notifications.
There more about this issue in this thread
Kevin Greaves
  • May 24, 2022
  • 12413 replies
  • May 25, 2022
To set this up:
Good luck...
