Roaming in Italy network not working
  • April 18, 2025
  • 9 replies
  • 653 views
I am in Italy and roaming is not working. This is the second time in the past 6 months. It was working perfectly till last December  Roaming is on on app on phone , no change of phone. Nettwork set on Automatic, picks up Wind3. I have switched phone on and off multiple time without any improvement, any other tips and advise? I need the phone for working. Thank you
Best answer by WelshPaul
Please reset your network settings and try connecting to 3 ITA or WIND.
You can manually connect to both networks via your network settings.
Please let us know how you get on.
  • April 18, 2025
  • April 18, 2025
It is Wind3 now should I manually 3ITA?
  • April 18, 2025
Thank you I will try now.
  • April 18, 2025
I know it’s Wind3 now. I read your post. Reset your network settings and then manually try connecting to Wind3. If it doesn’t work, try manually connecting to 3 ITA.
  • April 21, 2025
Hi ​@Susannadg
Thanks for posting.
We are sorry to hear you are experiencing issues whilst roaming.
It looks like the wonderful ​@WelshPaul is assisting with this issue but please do let us know how you get on and if you require any further assistance.
Thank,
Natalie
  • April 23, 2025
Thank you very much all sorted, it was a problem with roaming.
  • April 23, 2025
We’re glad to hear all is sorted ​@Susannadg!
  • August 23, 2025
I’m also in Italy struggling to connect. I’m on a cruise so it will be corfu tomorrow! Eek!! I tried the setting reset but that doesn’t work for my iPhone 14 (my updates are on 18.6.2)
  • August 26, 2025
Hi ​@helenpreest,
It may be worth trying to connect to all the available networks whilst you are on mainland.
If you have poor coverage it’s likely the coverage in that area. If you are unable to connect to data services and are using an Android device, please try update your APN settings.
The link below will provide further information.
https://community.idmobile.co.uk/roaming%2Dinternational%2Dtroubleshooting%2D215/i%2Dm%2Dabroad%2Dand%2Droaming%2Dis%2Dnot%2Dworking%2Dwhat%2Dshould%2Di%2Ddo%2D68325
