making phone
Hi Matt
hooe you can really help me
I can’t make phone calls and I’m really struggling this is now affecting my professional work and day to day to work also now it is leading to stress me affecting my mental health. I have contacted Apple to check my phone and it all seems good further the phone and the package was sold by ID and was assured that it is all volte enabled etc
this is now becoming a real issue and will will need escalation I will have to really contact consumer rights as I’m trying all my best I’m really struggling right now with a phone package and the phone sold to me by you and paying £50 a month
thanks and any help would be appreciated
Best answer by MZone
I’m using an iPhone.
Hide content
  1.  Make sure your iPhone software is up to date.
Here’s how:
  1. Open ‘Settings’.
  2. Tap ‘General’.
  3. Tap ‘Software Update’.
  4. If you have an iOS update available, tap ‘Install Now’. If you see ‘Download and Install’ instead, tap it to download the update, enter your passcode, then tap ‘Install Now’. Having issues updating? Check out this Apple Support article for more information.
  5. If you see ‘iOS is up to date’ - you’re good to go!
If you’ve confirmed that your iPhone is updated, yet can’t make calls, follow these steps to get back on track:
  1. Check signal strength & network outages.
 You can view the signal strength in your area with our helpful coverage checker and use the status checker to find out about any ongoing network maintenance activities or outages in your area. If you have an approved handset, enable Wi-Fi Calling for the best experience.
iD Mobile
  1. *IMPORTANT* Enable 4G (LTE) and 4G (VoLTE) Calling.
Before enabling 4G (VoLTE) Calling, 4G MUST be enabled. To check, simply follow the steps below:
  1. Open ‘Settings’.
  2. Tap ‘Mobile Service’.
  3. Tap ‘Mobile Data options’.
  4. If you have a 5G capable iPhone, tap ‘5G Auto’ or ‘5G On’. If you have a 4G capable iPhone, tap ‘4G’.
  5. If you have a ‘VoLTE’ toggle, ensure this is switched ON.
  1. *IMPORTANT* Re-enter your Mobile Number.
In most cases, re-entering your Mobile Number on your iPhone can resolve issues with calls.
  1. Open ‘Settings’.
  2. Tap ‘Apps’.
  3. Tap ‘Phone’.
  4. Tap ‘My Number’.
  5. Enter your mobile number, using +44 instead of the first 0.
  6. Tap ‘Save’.
  1. Force restart your iPhone.
The classic switch it off and switch it back on again. If you’re unsure how to force restart your iPhone, please refer to this Apple Support article.
  1. Toggle Airplane mode.
Switch on Airplane mode for 60 seconds. After 60 seconds, switch Airplane mode off.
  1. Perform a Manual Roam.
A manual roam resets your connection to our network, and can help with intermittent network problems. Here’s how:
  1. Open Settings.
  3. Tap ‘Network Selection’.
  4. Turn off the ‘Automatic toggle’.
  5. Choose a different network (Vodafone, EE or O2 - UK).
  6. Wait for 1 minute.
  7. Switch the automatic toggle back on.​
  1. Clean your SIM card.
If you’re still experiencing issues, you can also try removing, cleaning (with a microfibre cloth), and reinserting your SIM card.
  1. Dial this shortcode.
Open your Phone app and dial the below number to deactivate any call barring: #33*0000#.
  1. Using multiple SIMs? Set your iD Mobile SIM to primary.
For VoLTE to work, your iD Mobile SIM must be set as the ‘Primary’ SIM.
  1. Open Settings.
  3. Tap ‘Default Voice Line’.
  4. Select your iD Mobile SIM
  1. Perform a Network Settings Reset.
As a last resort, perform a Network Settings Reset on your iPhone. Here’s how:
  1. Open ‘Settings’.
  2. Tap ‘General’.
  3. Tap ‘Transfer or Reset iPhone’.
  4. Tap ‘Reset’.
  5. Select ‘Reset Network Settings’.
  6. Enter your passcode, then tap ‘Reset Network Settings’.
Please note: Resetting network settings will erase saved Wi-Fi networks and VPN settings. After the reset, you will need to re-enter Wi-Fi passwords and configure any other network settings as needed.
  1.  Test your SIM in another phone.
Remove your SIM and pop it into another phone. If you can make or receive calls on the other phone, then your iPhone might have a fault and may need repair. Check out this article for information.
Please note: Ensure the other phone you use to test is on our list of approved handsets.
If you’re unable to make or receive calls on the other phone, pop your SIM back into your iPhone and contact us for further support.
MZone
  • 1120 replies
  • May 4, 2025
Hide content
Here’s how:
  1. Open ‘Settings’.
  2. Tap ‘General’.
iD Mobile
  1. Open ‘Settings’.
  1. Open ‘Settings’.
  2. Tap ‘Apps’.
  3. Tap ‘Phone’.
  4. Tap ‘My Number’.
  6. Tap ‘Save’.
  1. Open Settings.
  1. Open Settings.
  1. Open ‘Settings’.
  2. Tap ‘General’.
  4. Tap ‘Reset’.
  • 3991 replies
  • May 5, 2025
Hey there ​@Subadushane, we’re very sorry to hear this. Please try the kind advice given by ​@MZone and let us know if any of the above helps.
If not, we will look into that further for you.
  • 12 replies
  • May 17, 2025
Hi none of the above is working
Either my sim is faulty or my phone is
both sold by ID mobile
what a disappointment and have caused it of issues in my professional and personal including my health now
I have no idea but rather find legal support on this contract
I’m really disappointed and one of your representative on an earlier occasion was mentioning how they can ‘dumb’ it down to me
sorry even that didn’t help
let me know how we can go ahead resolving
my phone and my sim both included in the contract which is £54 per month but provides me with nothing but a fancy gadget
